Jugamos a Frankenstein?
Vintage
Administrador de galeria
Hunterkiller Compressor... Fantástico nombre!!!
clasificacion de submarinos
* SC: Cruiser Submarine (retired)
* SF: Fleet Submarine (retired)
* SM: Submarine Minelayer (retired)
* SS: Attack Submarine (Diesel-Electric Power)[6]
* SSA: Auxiliary/Cargo Submarine (Diesel-Electric Power)
* SSAN: Auxiliary/Cargo Submarine (Nuclear Power)
* SSB: Ballistic Missile Submarine (Diesel Electric Power)
* SSBN: Ballistic Missile Submarine (Nuclear-Powered)
* SSC: Coastal Submarine (Diesel-Electric Power), over 150 tons
* SSG: Guided Missile Submarine (Diesel-Electric Power)
* SSGN: Guided Missile Submarine (Nuclear-Powered)
* SSI: Attack Submarine (Diesel Air-Independent Propulsion)[7]
* SSK: Hunter-Killer/ASW Submarine[8]
* SSM: Midget Submarine, under 150 tons
* SSN: Attack Submarine (Nuclear-Powered)
* SSNR: Special Attack Submarine (Nuclear-Powered)[9]
* SSO: Submarine Oiler (retired)
* SSP: Attack Submarine (Diesel Air-Independent Power) (alternate use), formerly Submarine Transport
* SSQ: Auxiliary Submarine, Communications (retired)
* SSQN: Auxiliary Submarine, Communications (Nuclear-Powered)(retired)[10]
* SSR: Radar Picket Submarine (retired)
* SSRN: Radar Picket Submarine (Nuclear-Powered) (retired)
* SST: Training Submarine (Diesel-Electric Power)
por cierto ya que estamos hablando de el, lo suyo es conocerlo un poco mas
http://www.youtube.com/watch?v=ywSuFL7bzQ4
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/ywSuFL7bzQ4&hl=es_ES&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/ywSuFL7bzQ4&hl=es_ES&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
Vintage
y mas..
aqui el S-81 en fase de construccion actualmente (febrero 2009)
entrega prevista 2013*
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/qv7k0Codn0M&hl=es_ES&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/qv7k0Codn0M&hl=es_ES&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
athen
Gracias Vintage por acercarnos más al proyecto.
Lo suyo sería que tuviera un dibujo del submarino en la esfera o en la trasera del reloj.
Bilhana
¿Dónde habré esado yo los últimos días para no haberme apuntado todavía a este proyecto? Bueno, en función de la estética de la esfera,... especialmente de que sea muy limpia, podés añadrme a la lista, de hecho so si si sabré esperar, estoy por lanzarme con la caja del francés para poder pasar la CRI hasta que el Hunterkiller Compressor sea una realidad...
pero,... ¿valdrá cualquier 2824 para esa caja? lo de la corona a las 4 y calendario a las 3 me desconcierta ligeramente.
Vintage
enga pues ya somos 18...
lo del calendario a las tres es simplemente porque estaba haciendo pruebas
para que el dial se parezca al del luxor aver como queda..
si cogemos las cajas francesas lo mas probable es que sea NO date.
y que este estilo de dial no le pegue
esto es por si aparecen cajas con corona a las tres y bisel exterior
uno mas y van #8.. este como el del luxor pero con los logos mas modernitos
y el Nombre Hunterkiller y la profundidad añadidos
me ha quedao un tanto "seiko" este..:oops:
Vintage
una version de este mismo pero no date y los logos en rojo
y en dial azul de propina
neurona
Bueno!!! pos otro que se apunta :guay:, pero yo votaría por un diseño mas clásico de esfera que los últimos, y por un nombre mas español...:rules:
saludotes
lubusssster
yo me apunto dependiendo del precio final del proyecto :)
como dice neurona a mi tambien me gusta mas este tipo de esfera
lubusssster
o estos
aunque por ser el submarino un modelo moderno me decantaria por el dial tipo IWC y las agujas del Lip, aunque el dial blanquito del Hamilton tambien me gusta :D
Vintage
saludotes
carlos tu lo quieres con maletin incluido? :rules:
estos ultimos diales serian solo para caja supercompressor de una sola corona y bisel exterior
luego intento hacer uno de corte mas clasico
Vintage
El ver como queda en una foto verdadera hace mucho..
la eterna batalla..mas clasico vs mas atrevido
personalmente no me importa que este inspirado en un reloj en concreto
pero no exactamente igual, para que nos sea una vulgar copia
y desde luego mientras no seamos suficientes no hay nada decidido
un hibrido tomando como inspiracion el lip #9
fotomontaje de como "quedaria"
robalon
como en su dia participe activamente en la realizacion de proyectos para el odisea en otro foro , que en un principio era sawc con doble corona , y luego siguio por otros derroteros , tengo algunos diseños que use en su dia . Os pongo una mezcla de lo visto hasta el momento , uso las agujas que mas han gustado con la esfera ploproff que es facilmente conseguible ( por ejemplo bill yao ya las tiene hechas ) , a mi personalmente me gusta como queda por que aun teniendo el mismo aire vintage lo moderniza algo .
tambien como punto de partida para el fondo pego algunos ejemplos para que veais el sub como quedaria ....... a mi me gusta y mucho
y otro de submarino
Espero que guste y mas aun que este proyecto llegue a buen puerto , siempre he tenido debilidad por los compressor , pero pienso que deberiamos darle un aire pseudovintage .... algo demasiado moderno , con la esfera muy recargada o con demasiado colorin creo no quedaria bien en el concepto de reloj que creo buscamos los amantes de la compresion relojeril.
athen
Tendremos que votar por un diseño entre todos, a mi los diseños que ha presentado el compañero Vintage me gustan.
Otra opción es hacer dos esferas, una más clásica y otra más moderna si no se va mucho de precio.
