pulga69
Esto es lo que ponía el anuncio del vendedor:
Here is a vintage Hamilton Khaki Military Style Field Watch, made in 90s, overall in good condition, the width of the watch is about 33 mm across (excluding the winding crown) and 42 mm from top to buttom, below is an approximate analysis:
Case = original brushed steel mid case body has some light wear, no rust or corrosion
Caseback = original steel caseback has some light wear, no rust or corrosion, factory writing is clearly visable
Crystal = original acrylic crystal has a few minor wear
Dial = 100% original Hamilton signed black dial is in good condition without any wear, tritium marker has aged to a yellowish patina, all writing is clean and visable
Hands = original hands have some light wear, in good working condition, with matching yellowish patina
Eso es lo que pensaba, en ese caso, el color es normal del tritio viejo, no es suciedad, así que habría que poner agujas nuevas.
Lo que sí hay que tener en cuenta es que el tritio es radioactivo y por tanto solo debe tocarlo alguien con el equipo adecuado....
