Girard-Perregaux Three "Blue Spinel" Bridges
enay
The Girard-Perregaux Laureato Tourbillon 3 Bridges was a favorite among the attendees during the Girard-Perregaux (SIHH) US press conference last month.
While the movement of the tourbillon cage, balance wheel and escapement will definitely catch your attention - surprisingly - the tourbillon is not what everyone was talking about. Instead, it seemed everyone's attention was focused on the beautiful see-through blue spinel bridges ("spinels" are gemstones). On the dial there are three bridges: one for the power barrel, one for the center pinion and one for the tourbillon mechanism. All three with a gold setting in the center and 2-flat-head screws securing them to the dial. Each mechanism exposed through a cut-out on the dial and perfectly visible through each translucent bridge. The exposed parts are polished and the surfaces are hand circular-grained. The result: a dial that is visually striking. Pure eye candy.
Fuente: Professional watches
Muy bonito, y seguramente muy, muy caro. Esos curiosos puentes están hechos de espinela, que es una variedad de piedra preciosa compuesta de aluminio y magnesio y teñida por oxidos de hierro, que se forma en cristales octaedricos, ideal para la forma que le dieron a los puentes.
Muy apropiado para hacer un super esqueleto translucido, pues es muy duro, indice 8 de la escala Mohs.
Muchas gracias por mostrarlo, amigo enay.
