Hola, pues si...
Stations
Several national physics laboratories operate radio transmitters that broadcast a time code signal. The following transmitters operate in the 40–80 kHz range and are used to synchronize radio clocks over areas several hundred to some thousand kilometers across:
* JJY: The first transmitter has 40 kHz, 50 kW and is located on the summit of the Otakadoya-yama mountain near Miyakoji-mura/Fukushima/Japan (37° 22' N, 140° 51' E).
The second transmitter uses 60 kHz, 50 kW, is located on the summit of the Hagane-yama mountain, near the border of the Saga and Fukuoka prefectures of Japan (33° 28' N 130° 11' E), and was put into service in October 2001. (photos)
* (OMA: 50 kHz, 50 kW, Prague/Czechoslovakia. Was in operation from April 1958 to Spring 1995. See also Martin Poupa's page)
* RTZ: 50 kHz, 10 kW ERP, Irkutsk/Russia (52° 26' N, 103° 41' E).
* MSF: 60 kHz, 15 kW ERP, Britain (currently: Rugby 52° 22' N, 1° 11' W; soon: Anthorn 54° 55' N, 3° 15' W), received throughout much of Northern and Western Europe.
* WWVB, 60 kHz, 50 kW ERP, Ft. Collins/Colorado/USA (40° 40' N, 105° 03' W), received throughout most of mainland USA.
* RBU: 66.66 kHz, 10 kW, Moscow/Russia (55° 44' N, 38° 12' E).
* HBG: 75 kHz, 20 kW, Prangins/Switzerland (46° 24' N, 06° 15' E), DCF77 compatible code.
* DCF77: 77.5 kHz, 50 kW (30 kW ERP), Mainflingen/Germany (N 50° 01', E 09° 00'), receivable up to around 2000 km from Frankfurt/Main (Germany). # HBG: 75 kHz, 20 kW, Prangins/Switzerland (46° 24' N, 06° 15' E), DCF77 compatible code.
# DCF77: 77.5 kHz, 50 kW (30 kW ERP), Mainflingen/Germany (N 50° 01', E 09° 00'), receivable up to around 2000 km from Frankfurt/Main (Germany).
El problema es el receptor (reloj), si el corte de ancho de banda del reloj es estrecho, no capta esa señal britanica.
El verdadero porblema aqui, no son los emisores, pues transmiten en el peor de los casos con 30 o 50 kW y con antenas gigantescas, cortadas y ajustadas a la media onda de su frecuencia, la cuestion es el receptor y su antena.
Probar a colgar el reloj en la esquina de una habitacion de vuestra casa, sin que toque nada, si la caja del reloj es el vivo a nada que toque cualquier cosa, incluido el cuerpo, estara cortocircuitada y eso en una antena omnidireccional es lo peor, otra cosa es que fuera una antena yagi (parrilla TV) pero eso son otros menesteres.
Si la caja es el vivo, pelar un cable largo, un par de metros...y sera una extension de la antena; Si la caja es la masa, que seria lo mejor...el cuerpo humano o una extension de un cable unido a la caja, haria de plano de tierra o contra-antena, la masa, toma de tierra o contra-antena, a veces hace que cambie muchisimo una antena y su lobulo de radiacion, tanto en recepcion como en transmision.
Espero...dentro de mis escasos conocimientos, ayudar a cualquiera de vosotros, un saludo.
