Pre-SIHH 2012 – JeanRichard Highlands Big Life limited edition
enay
The Brand has designed a limited edition of 100 pieces especially for the occasion, featuring a PVD-coated case twinned with a green outer rotating bezel indicating a second time zone. The numerals on the sober black dial are coated with ivory-coloured luminescent material, and the “ Big Life ” signature in red makes the model’s purpose clear: to support the foundation. A striking symbol inspired by the foundation’s logo and one of Nick Brandt’s most iconic photos, an elephant transfer appears on the sapphire crystal case-back, through which the JR1000 automatic winding movement can be seen.
The model’s technical design and the choice of colours have been conceived with the most demanding outdoor usage in mind. The model has been designed to strict technical specifications. The colours used and the absence of reflections make it ideal for use on a photo safari. Finally, the black fabric strap mounted on a folding buckle confirms the robust character of the Highlands Big Life.
Technical specifications
Case
Sand-blasted steel case with black PVD coating
Dimensions: 44.50 x 40 mm
Height: 11.96 mm
Antireflective sapphire crystal
Sapphire case-back crystal with Big Life Foundation logo
Case-back closed by 4 screws
Water-resistant to 100 metres
Screw-down crown
Bidirectional rotating bezel
Movement
JeanRichard movement JR1000
Automatic winding
Calibre: 11 ½’’’
Frequency: 28,800 vibrations/hour (4Hz)
Jewels: 27
Power reserve: minimum 48 hours
Functions: hours, minutes, seconds, date
Dial
Matt black dial
Luminescent Arabic numerals and indexes
Black hands with luminescent coating
Strap
Black fabric
Sand-blasted steel folding buckle with black PVD coating
Fuente:(HH Journal)
cibertris
madre mía.
y pensar que los primeros highlands eran casi iguales a los hamilton khaki de 36mm e inspirados en las sabanas de Africa.
nuevos tiempos
joxxan
Desde luego si que no pasa desapercibido de todos modos a mi no me dice nada... Pero ya se sabe para gustos colores y para jardines flores que dice el refran.
