Pre-BASEL 2009 - Maurice Lacroix Masterpiece Lune Retrograde Pre BASEL 09
Alvaro
Cada día me gusta mas Maurice Lacroix, están haciendo auténticas maravillas :ilove:
By alvarofl at 2009-02-13
By alvarofl, shot with Canon EOS-1Ds Mark II at 2009-02-13
Movement: Moon Phases Retrograde Calendar Maurice Lacroix Manufacture movement ML152, equipped with its own lever assortment, gear-train and spring balance, developed, manufactured and assembled in-house.
Functions: Hours and minutes indicated by central hands, retrograde calendar indicated by hand, visible through the dial at 10 o’clock, moon phases indicated by a disc at 6 o’clock, day indicated by a hand at 6 o’clock, power reserve indicated by hand, visible through the dial at 2 o’clock, vibration 18,000 vph, 2.5 Hz, power reserve 42 hours, 37 jewels, adjustment: 5 positions when fully wound and after 24 hours.
Decoration: Hand-decorated bridges plated with black-gold and featuring large snail-like pattern and dedicated moon phases disc.
Case: Combination of polished sunray, circular- and vertical-brushed surfaces, steel, 46 mm diameter, screwed steel bezel, domed sapphire crystal with anti-reflective coating on both sides, integrated shaped push-pieces to correct functions, screw-down crown in ¼ turn, screwed case-back featuring a large sapphire crystal with anti-reflective coating, water resistant to 100meters.
Dial: Functions revealed through skeletonized dial, main plate: slate-gray with vertical-brushed finish, skeletonized retrograde calendar and power reserve zones, applied ring: circular-brushed with polished applied slate-gray Arabic numerals, integrated skeletonized indicators for the retrograde calendar and power reserve functions, large opening at 6 o’clock for the moon phase indication, with an integrated metal-coated sapphire crystal, applied “Maurice Lacroix” brushed cartouches.
Fuente Jorge Merino
Jesus G
Me gusta mas el modelo con la esfera blanca...si que es algo recargado ...pero como casi todos los esqueletos
