Dos Nuevos IWC Ingenieur
Efilio
En la web de IWC se pueden ver las fotos (hay que registrarse). Os dejo en enlace:
https://www.iwc.com/index-en.asp
Platinum and Rose Gold Refine the Big Ingenieur
True greatness from within has been an intrinsic feature of the Big Ingenieur ever since its premiere. It was therefore an obvious step to accommodate its monumental seven-day automatic movement in a platinum case and in a rose gold case. After all, the refined appearance reflects the extremely attractive internal workings which, incidentally, are a trait shared by the entire Ingenieur family from IWC.
Ingenieur Automatic Edition “Climate Action”
For the Love of Our Planet
A carbon-neutral watch, made for a cause that benefits everyone – this is the Ingenieur Automatic Edition “Climate Action”. It is the symbol of a world that can be saved. Provided many people pull their weight. The campaign by environmentally aware management also helps. And IWC plays its part.
Ref. IW3234
Features
Mechanical movement, automatic Pellaton winding system, integral shock absorber system, date display, central seconds hand with stop function, limited to 1,000 watches
Movement
Calibre: 80111
Vibrations: 28 800/h / 4 Hz
Jewels: 28
Power reserve: 44 h
Winding: automatic
Case
Material: stainless steel and ceramic (zirconium oxide)
Glass: sapphire, antireflective
Back: ceramic mounting, stainless steel, engraved
Crown: screw-in
Water-resistant: 12 bar
Diameter: 44 mm
Height: 14 mm
Weight
Watch in stainless steel with black soft strap: 130 g
Seligra
Me encantan los IWC. Es una de mis marcas preferidas. El Ingenieur es un pedazo de reloj. Pero esta vez he sido incapaz de entrar en su web a ver los nuevos modelos. ¡Que demagogos! Todo vale:
Picón
Que decir, IWC es igual a calidad y elagancia.
Salutari y gracias por la informacion.
en mi particular y modesta opinión, a partir de la seria GST, que fue sublime....... la estética de los iwc ha ido perdiendo enteros, siempre tan instrumentos , pero con menos personalidad
y una vez que le ves las tripas a uno de los normalitos ( caros, sin remedio y sin tocar ni lo mas mínimo ), ves algún aquatimer con mas agua dentro que fuera y escuchas algunas interesantes historias sobre el big-pilot ( idolatrado por mi muchos años ), pues como que el pedestal se tambalea y estomáticamente se colocan a otro nivel un pelin inferior
por supuesto que es una gran marca, los portuges reserva de marcha ( creo que 7750 tocada como diría A.Nieto, "limite" ), calibres míticos ( fajones ) y relojes gran complicacion que quitan el hipo ( il destierro ), pero esa gama media, media-baja, baja, como que no es lo que yo esperaba
sed venebolos, por favor
