Erich Hartmann
Tenia mucho que no me metía a la pagina de los relojes mtm special ops, entre los nuevos modelos hubo uno que me llamo la atención, ¡¡ uno que mide la radiación !!
Les dejo la informacion que saque de la pagina oficial.
http://www.specialopswatch.com/products-page/rads/black-rad/
The MTM Black RAD Has Four Distinct Displays:
• 1) The Analog Watch Face,
• 2) The Graphic Display of Dose Equivalent Rate,
• 3) The Graphic Display of Accumulated Dose Equivalent
• 4) The Digital Readout Which May Be Switched Between
...... The Dose Equivalent Rate, Accumulated Dose Equivalent and The Time.
The EL Backlit Digital Display Shows Hours, Minutes, Seconds and The Date.
The Analog Watch Hands Indicate Hours, Minutes and Seconds.
The MTM Black RAD:
• Detects Gamma-Radiation With A Geiger-Muller Tube.
• Measures Dose Equivalent Rate (DER).
• Measures Dose Equivalents (DE) Of Gamma-Radiation.
• Shows Graphical And Digital Indications For DER And DE
• Allows User Presets For DER And DE Audible Alarms.
• Has A DER Indication Range: 0.1 to 4000mSv/h (0.01;0.1;1.0;10.0;100).
• Has A DE Indication Range: 0.0001 to 9999mSv.
• Has A DE Threshold Range (step): 0.001 to 9999 mSv (0.001; 0.01; 0.1;1.0;10.0;100).
• Has A DE Accumulation Time Range: 1 to 9999 h.
• Has An Accuracy Of Indication Ff DE:+/- 25%.
• Has An Energy Range: 0.06 to 1.5 MeV.
• Measurement time decreases automatically in the range: 300 to 2 s.
• CASE DIMENSIONS: 46mm Not Including Crown - 53mm Including Crown - 20mm Thickness
Once again, MTM exerts its leadership in tactical watch innovation. The newest in its line of tactical / technical models is the Black RAD Radiation Detection Watch.
The MTM Black RAD tactical watch includes a counter for detecting harmful ionizing radiation The Black RAD's integrated Geiger-Müller tube measures single-dose gamma ray levels, as well as cumulative exposure. The ultra- sensitive detector tracks dose equivalents – from 0.0001 to 9999 millisieverts (mSv), and the dose equivalent rate up to 4000 microsieverts per hour (μSv/h). Users can set their maximum radiation threshold, up to 9999 mSv, and an alarm will sound when this level (user preset) has been reached. Radiation levels are displayed graphically and can also be shown in the digital display, which can be switched between dose equivalent rate, accumulated dose, and the time. The time is shown via tritium illuminated analog hour, minute and second hands. The digital display is EL backlit. The MTM Black RAD is water resistant to 330’ and powered by a lithium battery. The case is titanium and the rugged nylon band option fits wrists up to 9 inches in circumference. The RAD is a unique technical instrument with a limited edition total of 1000 pcs.
The Black RAD is a must have for all radiological professionals and for those familiar with radiological terminology and its implications.
NOTE: The MTM RAD radiation detection watch is a serious instrument designed for radiation related professionals and radiologic technologists. Due to it’s intended technical purpose and subsequent critical readings, this watch is not necessarily intended for the casual user. The RAD instruction manual is written with the radiation professional in mind. The casual user or collector may have detailed and in depth questions as to the watch/detector’s proper use. An explanation of those basic questions is included in the RAD's operating manual. However, further technical questions regarding data - or its interpretation - will not be addressed by MTM customer service personnel should they arise by the casual user.
The MTM Black RAD:
