SIHH 2012 – Richard Mille Tourbillon Skull RM052
enay
Richard Mille secured the spot as the coolest luxury watch maker at the SIHH 2012 with the RM056 featured a few days ago. Now the skull and titanium Tourbillon RM 052 Skull watch takes the brand to a whole new plane of trendiness.
The skull is used not only for decoration but also as a functioning part of the movement. The movement’s center bridge has been constructed from the back of the skull and the ruby of the tourbillon cage is held between the upper and lower jaws. Four bridges connect the movement to the case and form the crossed bones of the skull and cross bone design.
Limited edition of 21 pieces, which includes 15 pieces in titanium and 6 unique set pieces in red or white gold.
Rumored Price: $700,000
Technical specs:
Power reserve:
  • Circa 48 hours
Case:
  • Dimensions: 42.70 mm x 50.00 mm x 15.95 mm
  • water resistant to 50 meters
  • 20 Spline screws
  • grade 5 titanium
Torque Limiting Crown:
  • This additional security system prevents from accidental overwinding, which could cause damage to the winding stem or putting extreme pressure on the mainspring barrel.
Movement:
  • CALIBER RM052
  • manual winding tourbillon movement
  • Movement dimensions: 32.80 x 30.90 mm
  • Hand-polished beveling
  • Microblasted milled sections
  • Drawn or polished outer faces
  • Tourbillon diameter: 10.90 mm
  • Balance wheel diameter: 9.12 mm
  • Number of jewels: 19
  • Balance wheel: GLUCYDUR, 2 arms, 4 setting screws
  • Moment of inertia: 11.50 mg.cm2, angle of lift 53°
  • Frequency: 21,600 vph (3 Hz)
  • Balance spring: in ELINVAR by NIVAROX
  • Shock protection: KIF ELASTOR KE 160 B28
Fuente:
http://www.theaffluist.com/richard-mille-tourbillon-rm-052-skull/
