SIHH 2012 – JeanRichard Diverscope LPR
enay
[h=2]JeanRichard Diverscope LPR[/h] Renowned for its technical and creative independence appreciated by customers endowed with a similar character, JEANRICHARD presents an original newcomer to its Diverscope collection.
Diverscope LPR © JeanRichard
After the initial titanium versions, this is the first model in the line to be presented with its distinctive cushion-shaped case made from polished and satin-finished stainless steel. The solid caseback is secured by four screws which, together with the screw-lock crowns at 9 and 3 o’clock – respectively controlling the hour&date and the internal bidirectional rotating bezel – guarantee water resistance to the respectable depth of 1,000 feet (300 metres).
This robust and reliable sporty model is powered by a 26-jewel automatic JR 1010 movement, based on the in-house made JR 1000 movement launched in 2004 and successively enriched since then with nine different evolutions. It features a balance oscillating at a frequency of 28,800 vibrations per hour and ensuring a 48-hour power reserve.
Clarity and originality
The extremely readable opaline black dial features a date display at 7.30, black & white hour and minute hands filled with a luminescent substance, along with luminescent-rimmed hour-markers and Arabic numerals. Among the latter, the number 12 stands in a particular way, since it empties and fills to provide a highly original linear power-reserve indication from which the model draws its “LPR” code name.
Like many successful designs, the technique behind this distinctive aesthetic and technical feature is surprisingly simple: a plate covered with a luminescent substance is linked to a cam via a conveyor support and a connecting rod, and this plate rises successively as the movement is wound and the numerals become white – meaning the power reserve is full. Much like a petrol gauge, this linear power-reserve then vividly displays the gradual depletion of the energy supply. Delivered with two straps – one in rubber and the other in a Kevlar® fabric – fastened by a satin-finished folding steel clasp with a double pushbutton security system, this is a watch clearly built for action and ready to accompany sports enthusiasts in their accomplishments both underwater and on dry land.
Technical information
Case
Polished and satin-finished stainless steel case Dimensions: 43 x 43 mm Height: 13.40 mm Antireflective sapphire crystal Case-back secured with 4 screws Water-resistant to 300 m Two screw-down crowns Internal bidirectional rotating bezel
Movement
JeanRichard movement JR1010 Self-winding Calibre: 11 ½’’’ Frequency: 28,800 vibrations/hour (4 Hz) Jewels: 26 Power reserve: minimum 48 hours Functions: hour, minute, second, linear power reserve indicator, date
Dial
Opalin black dial Emptied Arabic numerals at 12 o’clock Luminescent Arabic numerals and indexes Black and white hands with luminescent material
Strap
Delivered with two straps: black fabric and black rubber Satin-finished stainless steel folding buckle
Fuente:
http://journal.hautehorlogerie.org/en/news/sihh-2012/jeanrichard-diverscope-lpr-3210/
El sistema de reserva de carga es muy original, me gustan más con la corona del visel a las 10, tampoco me gusta mucho el calendario, desentona un poco en la esfera.
Claudio
Este de Juan Ricardo me gusta más que el del otro Ricardo, el "Millas". Por lo visto, hoy va de Richardes :rules:
